PSU wattage help
omghaxcode
376
what kind of wattage would I need for this:
4870 x2 Crossfire
WD 300gb VelociRaptor
WD 150gb Raptor
Cooler Master Cosmos S case
Mushkin 2gb DDR2 1066 RAM x4
Core 2 Quad Q9550
ASUS Rampage Formula
Samsung optical drive
HOOfan 1
2,337
15
Is that HD4870X2 in crossfire or 2 HD4870 in crossfire?
for Dual HD4870 I would go for 650+Watts. For dual HD4870X2...I would go for 800+ Watts.
Obviously brand and model also matter.
omghaxcode
376
anand tech suggests 1200 watts in their review of a crossfire system. anyone have any suggestions?
HOOfan 1
2,337
15
ATI has units as low as 900W certified for dual 4870X2. A really good 800W unit like the BFG ES-800 or other good quality 850W plus units would do. Or get a 1000W PSU, plenty of options there, although there are not as many for 1200W units.
omghaxcode
376
http://www.newegg.com/Product/...x?Item=N82E16817256041
how do you guys like that
well here is my problem. I ordered this and I need it to be enough power. if I open the box and it won't handle a full load then I'm screwed and can't return it for a refund. if I need a bigger PSU I have to know immediately because in 5 days I'll be in school.
psu listed above is only 10 bucks more after mir so do you suggest it or not?
HOOfan 1
2,337
15
Like I said...ATI has listed PSUs as low as 900W as being certified for dual HD4870X2.
The Corsair 1000W is more than enough. Don't listen to anandtech, their claims are preposterous. They even claimed you need a 1200W PSU for dual HD4850...which is just ridiculous.
omghaxcode
376
I don't mean to be an ass here but one of the general hardware mods said this
Originally posted by: MarcVenice
You're going to crossfire 2 HD4870X2's ? I suggest a better powersupply then, something 1200 wattish.
do you still believe undoubtedly that 1000 is enough? if so I'll keep it and open it but if you have any doubt let me know.
HOOfan 1
2,337
15
ATI HAS CERTIFIED SEVERAL 900W PSUS FOR DUAL HD4870X2 (Wow, these forums are kinda echoing...)
ATI's official list of PSUs recommended.
MarcVenice also had this to say
Here's the recommended list from ATI for crossfired HD4870 X2's. http://game.amd.com/us-en/cros...ex_components.aspx?p=3
True Power Quattro 1000W (TPQ-1000) can run two, which is 'just' $199. That silverstone isn't on the list but I bet it will work.
The HX1000 is a better PSU than the TPQ-1000
Buy a single HD4870X2, no need for a crossfire board like that.
Buy whatever you want with your money. It seems to me that you want someone to convince you to buy a 1200W PSU. No need to even ask the question if you are that set on getting a 1200W PSU.
omghaxcode
376
yeah I see that and it isn't on the list but I'll hope for the best. worst case it doesn't work and I send it back and pay the 15% restock.
HOOfan 1
2,337
15
Well the Silverstone isn't on the list either.
Neither is the Ultra X3 1600W
I am sure that ATI charges PSU makers to Crossfire certify them. Not to mention that they will not CF certifiy a board that is SLi certified....it is all about marketing.
If a PSU is capable of SLi then it is capable of crossfire.
Do whatever you want, it is your money.
JPB
4,064
89
It....will....work
omghaxcode
376
alright thanks for your help I'm just in a time crunch so I'm trying to be careful and get answers fast. I should be good. ty
