PSU too large for mATX case
MRGOOCH
2,292
I have been looking to use my current PSU a 750 watt in a new micro ATX case but it seems the case's won't take a PSU that is 7 1/8 inches long.
Anyone currently using a large PSU with a mATX case?
dma0991
2,723
It's hard to say as every casing is designed differently but I don't see the need for a 750W PSU in your rig in the first place. I don't think your rig will need more than half of what the PSU could output.
MRGOOCH
2,292
My intention is to build a new computer and thought I might use the great PSU I have. Most ATX boxes won't fit into my desk enclosure.
dma0991
2,723
If you're thinking of building a new rig with that casing, I suggest getting a new one. It doesn't even have a hole on the motherboard tray for easy removal of the heatsink. It is an older generation casing which is not suitable if you're planning on putting in an aftermarket heatsink.
If you don't mind with it and would still want to use that casing, a little bit of modding should solve the problem.
MRGOOCH
2,292
I am searching for a suitable case but the height and length are giving me a problem.
MRGOOCH
2,292
The only case that fits well is the Rosewill Challenger. I have read mixed reviews on it.
dma0991
2,723
Not liking the front panel of the casing, it looks cheap to me. The inside looks good though for a case for that price. Some ATX sized cases with the option for bottom mounted PSU should fit or a tight squeeze.
RavenSEAL
8,661
Get an Antec 300, that thing is insanely well designed.
My 750W PSU fit in there, and it was NON modular.
MRGOOCH
2,292
That case inside is the same as my old one except for the PSU being on the bottom. Is there a side panel on the right? How is it for cable management?
