PSU problems
What does the +3.3V rails supply power too? what ever it does, my voltage monitor catches it dropping out of its 10% threshold allowance.
Thanks,
BTRY B 529th FA BN
mostly the mobo though the sata connectors also. any orange wire is 3.3v.
keep in mind, you should be checking with a dmm, not software. and like lenjack said tolerance is ± 5%
Like rise4310 said, mostly the mobo. AFAIK, SATA drives don't use 3.3v even though they have the wires for it. That's why you can use an adapter off a molex.
also like rise4310 said, don't trust software or BIOS. If you have a question, check it with a digital multi-meter
