I had my power supply go bad this past weekend. I figured out that it was the power supply because when i took the 20 pin connector out one of the pins was black. The wire that goes to the blackened terminal is yellow, its the only yellow wire on the plug.
It was an ATX power supply, very common, is there a website that could show me what connects to this wire? I would like to make sure that this doesn't happen again, the way the pin is burned out, is seems there was a threat of fire.
Thanks
KP
Thanks
KP
