- May 26, 2008
- 4
- 0
- 0
Hi,
I currently have an eVGA 8800 GTS 320MB vid card. I?m also using a Thermaltake ToughPower 550W PSU.
http://www.thermaltakeusa.com/...er/w009697/w009697.asp
http://www.evga.com/products/m....asp?pn=320-P2-N811-AR
As you can see, there seems to be a mismatch in the 12V PCI rail. My card requires a single rail with 26A, while my PSU only provides 19A.
Would this cause major issues?
The reason I?m asking is that until recently, my computer was working fine. I?ve played Crysis, Gears of War, Neverwinter Nights 2, Bioshock without a hitch. And until recently, World of Warcraft.
My problems started a few weeks ago with WoW. I was using 4GB of OCZ memory (OCZ2P800R22GK).
http://www.ocztechnology.com/p...evision_2_dual_channel
My computer would start freezing up after a certain time spent playing the game. I would see certain artifacts on the screen, and would have to reboot. It wasn?t an overheating issue (my temps were kept well within specs, typically under 60 Celsius). This problem was made worse by Alt-tabbing out of the game to check info on the web. I then proceeded to check my RAM using memtest. Sure enough, one of the dual-channel kits came up with errors. So I RMA?d it to OCZ. My computer worked fine using the other 2GB, and I was error-free for over a week. Then, this morning, I started getting the same errors. I left for work, and left my computer running memtest. I?ll check it out once I get home.
Would my PSU somehow be responsible for these errors? This RAM was fine the last time I ran memtest. Now it?s acting up.
If it is my PSU at fault, why would it run fine for months?
