im trying to make the below rig as quiet and needing a low powered psu as possible..
duron 650 @ 733mhz (5.5x133)
abit kt7a motherboard
pc133 512mbs cas 2 settings
chaintech geforce 2 ultra (standard settings)
genius network card 10/100
56k modem
hard drive (as i want an ide model just waiting till i can aford one, but currently have seagate cheetah 36gig scsi running off of a adaptec 29160LP adaptor card)
floppy drive (no cd/dvd-rom drive installed)
if theres anything more i can add to help with this, please let me know,..
i was thinking of getting something like a 230W psu running, a smart fan and a 120mm case fan bolted to the side (with a hole obvously...
) to keep the temps down low as possible.. at the moment im getting a cpu temp of 35c and a case temp of 29c. without a slightly noisy 80mm case fan, it would touch 40c and perhaps the case temp would be as high as near 34c or so.. im just trying to get it as low as poss.. 25c for the cpu and 20c for the system temp would be great.. basically the lower the better
this machine will only be used for the internet when i have finally bought and upgraded to a new rig (amd 64 perhaps? depends when i pay my credit card off
bummer..)
is there anything that im missing or needing instead? any recommendations would be great! thanks guys and gals
56k modem
