PSU or Videocard problem.....
josh609
194
Hello everyone,
I'm having some issues playing games. I've updated my video card
drivers and everything else in windows 7 is up to date. The first
issue i've been having is textures in Starcraft 2 would start messing
up. Multi-colored or just wrong lay-out. Now i'm having a problem
playing games or anything that requires any amount of 3d graphics: bad
company 2, SC2, and even Google Earth. games or programs just freeze
for a few moments, and then they come back. At least in SC2 they
do........at times. At times i've had to reset my computer. The sounds
still continues to run while playing the game, but my monitor flickers
and a weird design comes upThe, and then my monitor goes black for a
moment, and sometimes SC2 will resume and everything is fine, until it
does it again. Periods between this happening can be several times a
match to maybe once every 2-3 matches in SC2. I think i narrowed it
down to either a bad video card or a dying PSU.
I have a Core 2 Duo E6600 @ 3.2Ghz
Radeon 4870 1GB
OCZ Gamextreme 600 watter.
6GB of Memory
I've had my computer for a little over 4 years now. The graphics card
is probably around 2 years old, while the PSU and CPU are over 4 years
old. So perhaps the PSU isn't supplying sufficient power to the video
card or perhaps the video card is just dying? I haven't overclocked
the video card......I'm not sure what to do.... :(
Any thoughts or suggestions would be appreciated!
Bartman39
Elite Member | For Sale/Trade
Jul 4, 2000
8,867
51
Textures is video memory so might be the video card going bad...?
A bad PS would mean OS crashes and for sure with an OC...
What motherboard do you have...? Might try another PCIe slot also...?
josh609
194
I have an Asus P5B Deluxe. My computer doesn't crash at all in windows. Everything is perfectly stable.
Bartman39
Jul 4, 2000
8,867
51
So assume the EVGA card in your sig is not in there...?
With the system stable otherwise I would for sure be suspect of the video card, also you indicate you OC`d the EVGA card so not this one...?
josh609
194
No unfortunately it's not. My brother and I switched graphics cards when he was programming with CUDA when he was in school. I now have his Gigabyte Radeon 4870 1GB.
