Alright so I own an XFX 550W Enthusiast PSU and have noticed a bit of a heat issue as of late. Here are the main specs:
Antec 300 Case
Intel i5 2500k Overclocked to 4.2GHz
8GB GSkill RipJaw RAM
EVGA GTX 570 Classified
XFX 550W PSU
WD 640 GB HDD
Anyway, so when I play Total War Shogun 2 the bottom of the tower, the metal side panel in particular, gets hot - like hot to the touch. The PSU itself doesnt make contact with the side panel.
I have the stock fans (2 in the front, one in the back, and one in the top) plus one in the side panel (blowing out) all running at the same time. The front ones are either on low or medium speed.
The PSU itself blows into the case - though I didnt know how to deal with that issue. So it essentially blows on the videocard under normal circumstances.
Ive used HWMonitor to watch the temps and neither the videocard or the CPU gets particularly hot. The CPU gets to mid 50s and the GPU gets to the mid 60s. (All while playing Shogun 2).
So is there a possible problem? I also have a Corsair A50 on the CPU. I know it isnt the best thing to have while overclocking but I havent been able to get another cooler just yet and Im deciding between a closed loop water cooler or a Noctua NH-D14 - though Im not sure if that one would fit.
Let me know guys! Thanks.
Antec 300 Case
XFX 550W PSU
WD 640 GB HDD
