- Feb 8, 2004
- 12,604
- 15
- 81
I installed my Antec Truepower 430W. But at the back where the gold fan is, the grate over this fan feels a lot warmer than the old Seasonic 300w i was just wondering if more heat comes with a bigger wattage?
Also i got a matx case and its made of thick steel, not flimsy crap like other cases this stuff is thick. So am i doomed to crap temps no matter what i do? It reads that overall system temp is 40*C the same as the processor at idle.... both hdd's are typically hotter than the processor at 43-44*C The ambiant room temp is around 26* or slightly higher now yea i know 40*C is nothing for a processor temp but i get the general idea that other things are usually *cooler* than the processor not hotter... Is there an effective solution to this except get a new case?
My cooling scheme:
2 80mm fans at back blowing out air
1 80mm sucking in air from the side*
Antec has 2 fans which do absolutely nothing that the seasonic single fan couldnt do.
*The side of the case has been removed after my comp reset itself.
My cooling scheme:
