I have a new system I just completed about a month and a half ago. So far everything has been running great up untill about a week or so ago. I noticed a weird buzzing/weak clicking noise comming from the case. I fiddled around a bit, testing case fans, etc and located the problem to be a fan in my ThermalTake Pure Power 420w PSU. One of the fan bearing is apparently crappy and at random times will start making that noise. Usually a few taps on the PSU itself will get it to stop, but it's beginning to interfere more often, and is just a general nuisance I don't want.
Is this a sign of a problem that will only get worse with time? Should I be concerned at all? Everything else relating to the PSU is fine, rail voltages are perfect, so there's no other problems. I'm just curious if it is going to become a bigger problem later on.
