PSP Wireless Woes
It detects my Wireless Router, and everything but it says this when trying to obtain a IP Address "A connection error has occured, the attempt to obtain the IP Address timed out"
Anyway to fix this?
Is security enabled?
Did you change the maximum number of DHCP clients?
Can your PSP connect to any other wireless connection without any problems?
I cant test it anywhere else...
No I didnt change it, becuase I cant get into it...
I cant log in to the router.
No Wep is not enabled
Have you tried rebooting the router? Sometimes can get hung up and by just unplugging and plugging the power to the router will restart everything and might fix your problem.
