Cliffs:
Port 1 on box is eth0
Port 2 on box is eth3
Port 3 on box is eth2
Port 4 on box is eth1
FULL VERSION:
I bought a Qoto Q310G4 box for a pfsense router/firewall. Love it, its small, works good, uses almost no power when idle.
BUT......
It has 4 intel gigabit LAN ports, its one of the reasons i chose it. however they are not labled correctly....
Everything i read says default pfsense setup is WAN on 1st NIC and LAN on second NIC. So i hooked it up this way, installed pfsense. Install went fine, booted up, confirmed it was working from the console dhcp was active was getting WAN IP life was good. NIC labled 0 was WAN and NIC labled 1 was LAN. Hooked up network cables to ports 1 and 2(as is labled 1-4 not 0-3).
And nothing works on LAN side, PC's dont get IP;s, cant ping the pfsense box, wireless AP not getting IP. Nothing worked on LAN port of pfsense box. Since i was restructuring my network at the same time and installed a new switch i thought it may be bad and the issue, swapped out with known good switch. same issues. Figured might be cable, tested all cables, all were good. Spent a good 4 hours troubleshooting different hardware configurations for the network, nothing worked. Then turned to software, maybe something was wrong with the pfsense install, ended up reinstalling a total of 4 times, each time it went normal, said it was working.
Then in a act of pure desperation i tried the other 2 LAN ports... and found out that the ports are labled 1-4, but thats not the order the NIC's are connected to them internally.
So as soon as i plugged lan cable into lan port # 4 on pfsense box everything seemed to work fine, yay problem solved.
Then i spend 2 hours configuring the firewall, weird things started happening to some connected clients, and it turns out that the pfsense image i downloaded and put on a USB stick was corrupted, so i had to redownload reimage it to USB stick and resinstall pfsense for the 5th time. At least this time i knew which LAN ports were really which. And all is running great now. I cant even remember the last time i had a corrupt download thats why i didnt check it previous to install.
I was having a rough night last night, no luck....
FULL VERSION:
BUT......
