Squisher
http://www.lsgc.com/recall/
LED Light Bulb Par20, G25 and A19
The bulb can separate, posing a possible fire risk to persons and property
The affected bulb models are A19, G25 and R20 (also known as PAR20) LED bulbs. The model type will appear alone or with one of the following prefixes: ECS referring to Ecosmart (a brand of Home Depot); DFN referring to Definity (a brand of LSG); OSI referring to Osram Sylvania; or WHP referring to Westinghouse. The suspected bulbs are identified by a date code from October 2010 to March 2011. These codes can be found at the base of the bulb printed in the format L4810, which would indicate the 48th week of 2010 (i.e., Nov 29th, 2010).
Stop using your bulb and contact Lighting Science Group
(855) 574-2533
(855) 574-2533
