daniel1113
- Jun 6, 2003
- 6,448
- 0
- 0
Eh. My computer is on 24x7, and I've gone without restarting for nearly two months. I use hibernation on my laptop every night, though.
Originally posted by: MmmSkyscraper
Stop posting!
(to conserve power)
Originally posted by: loup garou
I use hibernate on my laptop, but S3 on my desktop for wake-on-lan if I need to connect to it from work. I also use S3 on my mediacenter box for the same reason, it also wakes up to record any scheduled shows then goes back to sleep. Can't do that with hibernate.
Originally posted by: dug777
Originally posted by: buzzsaw13
I also use shutdown, it only takes about 30 seconds to boot into windows.
That's great mate
In my case, startup takes quite a while, since my XP install is ancient & i have a boatload of crap that initialises each time.
Hibernate is almost instant however.
If you bother to read the OP, rather than being an argumentative little twerp, you'll notice i'm addressing people who use standby primarily, as it is almost totally irrelvant as far as i can see![]()
That's great mate
PSA: Don't install a bunch of crap that slows your machine down.
Essentially, S3 is an even more power-saving suspend mode. It shuts off power to all devices except RAM, unlike S1 that will keep fans, CPU and HDs running.Originally posted by: Aflac
What's the difference between S1 and S3 standby states? I see the option in my BIOS but I don't know what it means.
Could you explain that in more detail? Sometimes I debate leaving my computer on during the day depending on whether I think I'll want to connect it from work or not. Could I use that to essentially have it hibernate but then still remote desktop to it if I want to and have it wake up?Originally posted by: loup garou
Text
If you want to enable S3, but your bios is set to S1, you'll need to reinstall windows or I believe there are some reg hacks you can do.
There are also some new sleep technologies coming with Vista I think.
