PSA: Hibernate makes standby/sleep mode irrelevant, and saves as much power as shutting down...
dug777
24,778
4
I hibernate anytime i'm going to be away from the comp for more than say 15mins, since it's incredibly quick to come back to life, and restart about once a month for driver changes and a general de-crankifying of my XP install that is begging for a cleain reinstall...
If i catch any of you using standby again, i'll kick you in the nuuuttttsss! ;)
dug777
24,778
4
Originally posted by: buzzsaw13
I also use shutdown, it only takes about 30 seconds to boot into windows.
That's great mate ;)
In my case, startup takes quite a while, since my XP install is ancient & i have a boatload of crap that initialises each time.
Hibernate is almost instant however.
If you bother to read the OP, rather than being an argumentative little twerp, you'll notice i'm addressing people who use standby primarily, as it is almost totally irrelvant as far as i can see ;)
dighn
22,820
4
shutdown is the superior choice. you are scum.
Raduque
13,140
138
WRONG! And you should be eradicated with hot pokers!
dug777
24,778
4
Noes, you are teh scum, n00b ;)
My choice is an almost instant hibernate start, or a few mins waiting for all my crap to sort itself out & initialise...i wonder which is better for me?
Plus, and here's teh bit where you really are a n00blet, shutdown closes all your apps, whereas hibernate leaves everything as it is. So once you take into account opening all the stuff i'm working on, finding my place in pdfs, and opening up a few browser tabs, hibernate would utterly pwn shutdown on any system in that scenario.
get with it ;)
0roo0roo
64,795
84
shutdown? booo, i don't like having to close all my tabs and hope my session extention saves them all withotu fail and all the other cr@p i have open. and yes hibernation works. standby is fiddly on most pcs, there are several different modes or something, depending on your setup, some ofthe less deep modes are near worthless.
dug777
24,778
4
Originally posted by: Powermoloch
I use the shut down button
"hugs trees" :evil:
*beats Powermoloch over the head with a computer in hibernate mode, that is disconnected & powered down*
jagec
24,442
"hugs trees" :evil:
Hibernate is, if anything, more energy efficient than shutdown, since you don't have to take the time--and CPU cycles--to reload everything when you start up again.
dman
9,110
I recently bought a new UPS which has a KWh meter on it. With the PC & LCD on the system uses 130-180W of power. In standby it still uses close to 100w. I thought it'd be much less, but, it's still using quite a bit of juice to spin the fans. This is an XP 2500CPU and NForce2 MB in an antec case w/ 400W Powersupply.
sunase
551
hibernate takes forever on my laptop (2gb of memory being saved to a laptop hd). suspend is superior.
Powermoloch
10,084
4
"hugs trees" :evil:
It's all in personal preferences :p
dug777
24,778
4
Originally posted by: SynthDude2001
*throws tomatoes at dug*
:heart:
*makes tomato & chilli sauce, invites synth around for a BBQ and vast amounts of :beer:*
CrazyDe1
3,089
Hibernate takes up 1Gb of HD space and I only have 6.5 GB for my primary partition...standby mode for me.
dug777
24,778
4
that is a midgety partition ;)
walkur
774
8
The anoying thing about hibernate is when it locks op during startup.
You then get the choice to retry or restart normally.
The problem is it doesn't recognize my wireless keyboard :-(
