Krazy4Real
LMAO! This.Seems like changing the batteries would've been the first thing I'd have tried if it says battery low 🙂
How does the programming lower your bills?
If you get a flat tire do you rotate the tires, then drive home?
Seriously. You're on a boat. How in holy hell do you have time to read all this shit? Don't you ever go out and lay by the pool? Can you explain molecular orbital theory to me?Lesson learned here is a liquid crystal display can still switch on a very weak power cell! When that low batt icon is displayed it's important to replace 'em because they will eventually get too weak to close terminals calling for heat/cooling etc.
If you don't need setback, etc. T87F FTW. No batteries, no worries. 😉
If you're freezing you can also pull the 'stat off the sub base and get out a few "roach" jumpers...
The R terminal is "hot" and when jumped to other terminals will bring on the heat. When R+G are jumped you will have your fan. Jumping to W will give you heat, Yellow cooling. If you have a heat pump and need cooling you will need to jump O as well (for the reversing valve to energize) or otherwise you will still get heat. This is a fail safe as it's generally better to fail in heat mode than cooling mode, etc.
Don't worry about these wires/terms because it's all 24V and you won't feel a shock unless you lick them. :biggrin:
My dad would just turn the thermostat down before leaving the house. I was taking in their mail for the week they were in Mexico and the house was cold as hell. Probably like 10C instead of the usual room temperature of 20C.Allows you to set lower temps during time you are away from home
Strange, I didn't know some thermostats required batteries.
Mine is hard wired.
Our thermostat is really sensitive with it's batteries. If they dip too low, it tries to turn on/off the furnace very quickly over and over, causing the furnace to make a loud electrical buzzing noise. The thermostat doesn't have a low battery warning light, but we know when they need to be changed based on that sound coming from the furnace.
It took our HVAC repair guy a while to figure that one out.
Yeah that's really bad for the AHU blower relay/contactor.
i just avoided an HVAC service call by cleaning my flame sensor
go me.
Since when do thermostats take batteries?
The thermostat in my house takes batteries, but IIRC, they're for memory rather than operation.
