PS3 HDD swap for 7200rpm heat output question
FuryofFive
1,544
9
I picked up a ps3 a couple weeks ago, since then ive bought maybe 6 games.
i rented another game that literally took like 10-15mins to install on the drive, which is a WoW,
On top of the extra storage.
for those who have done this, how is the heat ouput for the faster drive? is it something to worry about?
Queasy
Moderator<br>Console Gaming
Aug 24, 2001
31,796
It isn't the speed of the HDD that causes the slow installs. It is the speed of the Blu-Ray drive.
nakedfrog
62,897
19,130
Yeah, when I popped in Ratchet & Clank Future on my birthday, it was lame having to sit through an install before I could start playing.
FuryofFive
1,544
9
theoretically. shouldnt it be faster because its moving larger chunks of data?
Queasy
Aug 24, 2001
31,796
Nope. The size of the date on the disk has nothing to do with the speed of the data transfer because of the read speed of the Blu-Ray drive itself. That's why many PS3 games duplicate and triplicate data across the disk to help with read speeds.
There was an article the other day about one of those extreme tech sites putting a Solid State Hard Drive in a PS3 to see if it would help increase performance. It didn't do much because the bottleneck is still the Blu-Ray drive.
FuryofFive
1,544
9
ahhh ok, wont i see a different though when loading games though? and when loading stuff off say a usb drive? cuz i probaly will be using this for a makeshift HTPC
Queasy
Aug 24, 2001
31,796
Gamepro ran a test and they showed only a couple of seconds are gained during load times.
The main reason for upgrading a PS3 to a larger HDD will be space space, not speed.
FuryofFive
1,544
9
yeah i read that..those test are simply done with simple tasks
what about loading a 1-2gb file on to the drive? instead of taking 10-15mins, maybe take 5...or installing a demo, instead of taking 15mins...taking like i said 5?
Queasy
Aug 24, 2001
31,796
Haven't seen any tests on something like that. I would imagine there would be some kind of improvement for anything where the Blu-Ray drive wasn't the bottleneck. Don't know how much of one though.
Golgatha
12,402
1,078
Loading a file to the internal HDD (150 MB/sec, SATA 1.0) will be bottlenecked by onboard GbE (125 MB/sec), external HDD (due to USB 2.0 interface, 60 MB/sec), or USB thumb drive (60 MB/sec). Installing a demo is mainly a file decompression task (think WinZip, WinRAR, or 7-Zip), which is CPU limited. Even one of the top of the line Intel X-25E SSD drives will max out at 150 MB/sec due to the SATA 1.0 interface.
My advice, buy the cheapest 5400rpm, GB/$ drive you can find for the PS3 when you need to upgrade.
Krazy4Real
12,221
55
I installed a 320 GB 5400 rpm drive in my PS3. During game downloads or installations I just switch the input over to cable tv until I notice the hard drive light stop flashing. The bottleneck is definitely the blu-ray drive and not the hard drive.
FuryofFive
1,544
9
ok but still, if the drive is spinning faster, shouldnt that still cut time off, maybe not in half, but a decent chunk?
FuryofFive
1,544
9
is there a site where someone tested this out? not just the small gamepro tests but on a larger scale. and not based on specs
thilanliyan
12,064
2,277
I've read that putting a 7200rpm one in there may not help because of some sort of encryption that has to be done by the system itself (which would be the bottleneck for HDD speeds). It was in one of those tutorials on how to change the HDD. I ended up just putting a 160gb 5400rpm drive in there. It'll run cooler anyway and I don't do large file copies or anything like that. Plus, installing is only done once.
FuryofFive
1,544
9
yeah,i think im considering probaly doing just that, gettign a 200gb 5400rpm drive, what speed are the drives to begin wth...i know they like to stick slow cheap drives in there
Dari
17,133
38
Sounds to me like you've convinced yourself of buying a 7200RPM drive and want outside confirmation. But, as others have said, a higher RPM doesn't give you much, if any, advantage. Worse, it may cause overheating in the long run.
FuryofFive
1,544
9
wow lol did u not read the post just before this one.. im amazed at how silly you are... i said clearly that ill probaly get a 5400... but i guess u got me there :)
Dari
17,133
38
I didn't read the last one. But the drives are dirt cheap now. Most are under $100.
randay
11,018
216
first of all: how big is the hard drive in there now? and are you running out of space?
secondly: you wont get faster installs no matter what hdd you upgrade to. if anything you will get faster load times when playing games off the harddrive, but those load times should be pretty non-existant already.
i would say to upgrade only if you need more space... but this has all been said already.
FuryofFive
1,544
9
i have the 80gb, with the demos i have now, that took up like a good chunk, had like 30gb's left over, and i havent even put movies on it. waiting to upgrade the drive first.
Thraxen
4,683
People need to clarify what they are saying here. There are two types of installs. You won't see any increase in speeds for installs retail games like MGS4 do off of the discs. It's the BR drive that the bottleneck in those cases. You will see slightly lower load times for installs of downloaded content.
IMO, the few seconds saved is trivial. I don't care if I save 10 seconds on a one-time install or 2 seconds on loading a game off the HDD. I'm about to spend 20 minutes to several hours playing games... it's trivial. I'd rather spend the cash I would have spent on a faster drive on a bigger one instead. But if the biggest drives are available at both speeds and I had the money for either, I don't think there are any major reason to not get the faster drive.
thilanliyan
12,064
2,277
It's either a 4200rpm or 5400rpm...mine was a Seagate 40GB I think...I don't have it with me to check the speed though.
Oct 20, 2005
10,978
44
If i've filled up my stock 80gb HD and want to upgrade to something larger, how would I go about transferring the data over to the new HD?
Trader05
5,096
20
the only thing i know that works is backing it up to an external drive, has to be formatted FAT32. Backup, install new hard drive, restore. Worked for me 2 times without a hiccup.
