Originally posted by: Matthias99
Originally posted by: archcommus
I was using my PVR software, BeyondTV.
Something like DScaler provides excellent quality, but would it help the lag on its own? I read in another thread that lag is more likely with cards with hardware MPEG-2 encoding (mine has this). Why is that?
Uh, because hardware MPEG2 encoding isn't instantaneous. And there's usually no way to bypass the encoder on hardware encoder boards.
BTV could be adding further delays of its own; I haven't tested to see if it's any worse than something like AMCap or DScaler (I use it as a PVR, so a lag on the inputs is irrelevant).
Generally, if you want to run a game console through a capture card, get a software-encoding card (the really cheap ones that are like $30). Then you can just watch the raw feed without it doing any encoding or post-processing. Or actually lay out the cash for a VGA transcoder.
