Originally posted by: mizzouXC
this adapter comes free with most usb mice.... what a steal..
Originally posted by: c627627
Do not use USB mouse without a PS/2 adaptor and avoid USB keyboards.
They do not work in DOS, BIOS.
USB signals can be processor intensive so the system will run faster if PS/2 port is used.
No matter how often that myth is repeated - the adjustable rate on PS/2 is NOT an advantage, but merely a kludge to let the user balance between smooth mouse movement with high system load and jerky pointer motion at low system load. Note that fast CPUs don't help, since the access times toward this historically ancient piece of silicon that is the keyboard/mouse controller (we're talking 1977, 8-bit ISA here!) are astronomical.
On USB, which is a bus mastering PCI device, smooth pointer movement and low system load aren't contradictory goals, so there simply is no NEED to make anything adjustable.
USB. Twenty years of progress over PS/2.
Did you not read wallsfd949's post? :disgust:
Originally posted by: Keltron
total comes out $13.59 after shipping. I can pickup a usb keyboard at local store for $10. and the same converter is sold at Big Lots for $10. I dont think this is a hot deal
Actually guys, at the same sampling rate, a USB mouse(or keyboard really) is MUCH more CPU efficient than a PS/2 mouse...
The effort needed by the system to constantly poll the PS/2 port actually used quite a bit of CPU...
If you don't believe me, run the same mouse at the same polling rate on PS/2 and USB and look at your CPU charts when you're moving the mouse around. There should be a BIG difference if you have a slower PC(I suppose it'd be hard to tell if you had some 3.6Ghz overclocked P4 or something)
Scrolling around in explorer uses up to 7%(it fluxes but 7's the highest) of my CPU to do the mouse stuff...but that includes a lot of drawing, etc.
In IE it seems to use more, probably because I'm typing this right now and it's probably trying to figure out if I'm switching windows, or about to click something, whatever(I say this because iexplorer.exe was the one with rising CPU usage during this).
But if you aren't moving your USB mouse around it drops quickly to 0%. I think a PS/2 mouse would keep using CPU regardless since it has to keep polling the port.
