- Aug 12, 2001
- 40,730
- 670
- 126
Many motherboards, especially gamer-oriented ones, still include a single PS/2 port with it colored purple + green to indicate it supports both keyboards and mice.
Of the several I've owned, none included a Y-cable for if you want to use both.
Has anyone had luck using a Y-cable, and can you point to a specific model at Newegg or Amazon? The motherboard I want to use it with is an ASRock Z370 Extreme Pro4.
Most of the cables I found with a search said they were for some old motherboard and had people saying they didn't work on anything else.
