Using a Ubiquiti Wifi router in my home with signal strength maxed out (28 dBm). Have separate building about 100 ft away where Wifi is marginal and area beyond where Wifi is absent. There is unused coax (RG-59) run from house through conduit. I want to improve Wifi signal in separate building. Any advice on the following options would be greatly appreciated.
1) Look for Wifi router/access point with greater signal strength to deploy in my home.
2) Implement Moca over the RG-59 with total cable length 120-150 ft and put access point in separate building (never having done this would access point simply extend my existing Wifi network with same SSID?)
3) Yank out the RG-59 from the conduit and put in either Cat 6 or a Cat6/RG-6 combo. Put an access point in the separate building on the Cat6.
I like the idea of an access point wired to home router because I assume more robust and could expect good Wifi coverage with second access point. But I don't have experience with cabling in conduit and putting end connectors on bulk cabling.
I'm assuming the Moca over ~150ft of RG-59 is not a good idea.
I don't like the idea of a very powerful access point that is beyond my requirements (such as 10km range devices).
Thanks for any advice.
