- Oct 18, 1999
- 450
- 0
- 0
Has any one ever had any problems after defragmentation. Any real gains? I seem to remember PC World magazine saying that it was absolutely not needed.
Thanks
Thanks
Originally posted by: PurdueRy
I see no cons and therefore I do it
Me too. I use diskeeper to do it. Far superior to the standard windows fare.
Originally posted by: mshan
Is there a particular level of fragmentation where "symptoms" start to arise (a new slowness?)
Or is there a rule of thumb % fragmentation when I should always defrag?
And is there any danger (e.g. excessive hard drive wear) from frequent defragmentation (like every week or so)?
same here
same here
It's not any better. They use the same engine in the end if you realize that. Moreover, using Diskeeper just slows your system down because it adds one more thing running in the background.
I used to use Diskeeper, but now it's all about optimizations so I'd rather not have a bunch of crap running. MS defrag ftw.
Edit: I defrag my Windows partition at least once a week, the Vista and Games partitions constitute another 140gb, but those rarely get touched and it's not like defragging is day and night for those partitions, and so Windows is the only one I keep well maintained.
If you defrag often, there's nothing wrong with MS utility because it shouldn't take that long. Worst case, just leave it on overnight.
same here
I disagree. While the windows defrag tool is made by the diskeeper corp. that does not mean they are on the same level. I believe it does do the job significantly quicker but it also defrags better. I found that the windows utility would sometimes have to be run multiple times to achieve a file structure free of fragments. Not the case with Diskeeper.
My favorite feature is the boot time defrag. A feature not available in the windows version. It condenses all folders to the beginning of the file structure and defrags files that normally can't be touched due to use by windows(paging file). This helps save from future fragmentation by making more continuous portions of the hard drive open for the larger files that most often become split up into pieces.
same here
All that and you don't have to have the realtime defragmentor running if you don't wnat to. I just run it once a week and it helps keep my system zipping along quite nicely.
Originally posted by: 0roo0roo
to be honest i've never noticed a difference, even when i had a 486it was just something u were told to do...defrag and harddrive. so u would....
Originally posted by: randomlinh
i miss norton's speed disk or whatever it was called. that worked great. now when I defrag it doesn't seem to do much. the before and after picture are nearly the same for me (both windows and diskeeper)
