Not enough to make a significant difference.. you're talking about what, 2 spark plugs? lol....Originally posted by: Fingers
4 cylender would be cheaper to maintain.
Originally posted by: Vic
All things being equal, power and torque should be similar. Power comes from displacement (and/or forced induction), not the number of cylinders.
Everything being equal, the 6 would be smoother than the 4 in almost any configuration (V, flat, inline), but would be more expensive to build and maintain. The 6 would weight a bit more. More cylinders usually mean more space taken up under the hood. All things being equal, power and torque should be similar. Power comes from displacement (and/or forced induction), not the number of cylinders.
Originally posted by: jagec
4-cylinder is less complicated, smaller, lighter, revs higher, and (in all cases I've seen) will get higher fuel efficiency.
6-cylinder probably has a better torque curve, the components are less stressed, and you get to slap the "V-6" emblem on the back of your car.
Frankly, I don't think I'd ever want a V-6...I think 4-bangers, I-6's, and V-8's are the best engines.
As jagec mentioned, though.. that isn't entirely true. Like I said, you could do anything you wanted with the two engines as far as power output goes.Originally posted by: vshah
basically what i was wondering about, thanks![]()
A well designed 6cyl could easily trump a poorly designed 4cyl in every aspect, and vice versa..
It's never been about the peak HP/torque, it's about the curves...and that's a function of more than just displacement.
Originally posted by: otispunkmeyer
v6 is smoother.......becuase of the "V" the engine in more balanced....the pistons are basically pushing against them selves.....in a 4 pot, the pistons move straight up n down and the all they push on is the crank shaft....even what happens is crank gets bit misaligned and u get a knocking noise
4 pots are generally rougher....or at least will become rougher with time much quicker than a V
Not entirely correct. A V6 is not a very balanced engine, scarcely more balanced than an I4 and less balanced than a H4. What makes the 6 feel smoother is that extra fire every revolution. Now the I6 is perfectly balanced.... and the pistons all move straight up and down. What makes knock in a well-maintained engine is usually poor fuel grade and/or overly lean AF mixture.Originally posted by: otispunkmeyer
Correct. Torque curve and redline have much more to do with bore/stroke, compression, cam profiles, and flow rates than with the number of cylinders.Originally posted by: OS
Well, notice his initial qualifier, "all things being equal". If you kept the bore/stroke ratio same, timing/ignition, fuel grade, cam profiles/timing setup, flow rate of heads/manifolds, whatever else i didn't think of, blah blah blah, all the same, it pretty quickly boils down to displacement.
All things are not equal between those two engines. Volvo designs more power into the 5cyl because a high output I4 tends to be rough and buzzy, while the I5 design is relatively smoother.Originally posted by: Nebor
All things being equal, a 2.4l 4 cylinder generates less power than a 2.4l 5-cylinder. This isn't theory, it's been proven by the Volvo guys, who have both 2.4l n\a 4 cylinders and 2.4l n\a 5 cylinders.
actually, an I-6 engine is considered "perfectly" balanced. A V-6 is not.
Originally posted by: 0roo0roo
look at stuff like the evo and wrx, those are 4bangers that can wipe out most v6's.
I think that you are basically right, F1 engines have lots of cylinders, but a low displacement and rev to crazy speeds.Originally posted by: thomsbrain
actually, i'd guess that the 6 would rev higher, given identical displacement and internal design. the reason is the moving parts for each cylinder would weigh less and therefore not beat the crap out of themselves so badly. i'm sure there's other factors i'm not considering, but that's just what came to mind.
edit: and you can't use most common engines as your excuse to say i'm wrong, because few of them share displacements and none of them share designs... i'd love to hear if i'm wrong or right from a phsyics standpoint, but i don't want to hear any "well the S2000 revs higher than a big-block Chevy, so more cylinder MUST rev slower!!!111"
Originally posted by: freebee
Always pick the 6. Each cylinder actually fires less, meaning less wear over the life of the car. Engine will last longer. Makes sense?
