So here's my situation:
I'm buying a new P4 3.0c soon and I'm mounting a nice n' noisy 92mm Tornado on top of an SLK-900U HS. At top speed, a Tornado will move 113 cfm.
I also will have 5 80mm case fans that move 39 cfm each, and 2 PSU fans as well. Two 80mm fans will be used for front intake, and two 80mm's will be used for rear exhaust. The last remaining 80mm fan is a side-mounted fan.
Here is my situation and question to you all:
I'm not sure if I should make this side-mounted fan and intake or an exhaust fan. If I do make it an exhaust fan, I will have a total of 3 exhaust fans moving a combined total of 117 cfm. This would be great because I will be getting rid of the full 113 cfm that the 92mm Tornado is dishing out.
HOWEVER, if I make the side-mounted 80mm an intake fan, it will most likely be blowing air over my video card helping to keep it cool as well. But in this event, I will only be moving 78 cfm from my case, leaving an additional 39 cf of hot processor air in the system.
Although I will have 2 fans in my PSU, but I'm not sure how much cfm these puppies can move, and how effective they are in helping case-cooling. The PSU will be an Allied TRUEPOWER 450w.
Any thoughts on this?
