Proper way to "secure erase" a Samsung XP941?
Synomenon
10,547
Ok, so secure erasing a Samsung XP941 can brick it.
What's the proper way to wipe it and restore performance if I've borked the Windows install on it?
Elixer
10,371
762
Not sure why a secure erase command would brick it, either it supports the specs, or not.
If not, it shouldn't allow the secure erase command.
I know sammy has utils that you can burn to a dvd or usb stick that should work as well.
There is also hdparm from a linux boot distro that you can use.
