I ordered the parts and tools needed to make Molex connectors using Mini Fit Jr. Wondering what is considered the appropriate way to make Y cables, can you just double crimp on the same input pin? Or is it best to splice the wires together, solder and shrink wrap? Obviously need to be concerned about the amperage if I split too many times as well, 18 awg is good for what, around 12 amps I think? So an 8 pin would do about 48 amps give or take? Probably want to slightly derate that as it's not guaranteed all conductors will share the load equally.
This would be for GPUs/mining so need to do it right considering the amount of current going through. Yeah you can buy them, but what's the fun in that? 😛 I also been wanting to play with Molex and different connector types anyway for other projects that may make use of them.
