- Mar 1, 2007
- 282
- 3
- 76
I put in an X6 1090T this weekend and it works great but I noticed the temps seemed a bit high (up to 57C under load with stock cooler). It was running at 1.45v according to core temp and overdrive, so I was able to bump it down to about 1.35 using overdrive and it seems OK running F@H. 1.25 was a bit low and caused apps to crash.
So, what is the stock voltage for this processor?
I'm working on it remotely so I can only change it through overdrive for now but as soon as I get home I want to change it in the bios.
