- Aug 28, 2001
- 52,844
- 1,049
- 126
I've been doing a few things to my wheels so I've had to use a torque wrench at home quite a bit recently. Read an article that stated I should drop the wheel to where it's just touching the ground to stop any rotation but no load and only torque halfway. Then drop all the way and torque to spec. But shops with lifts always do everything with no load, and with an impact wrench no less. My fronts spin freely if up in the air so doing it by hand is different. Logically it seems tightening with full load prevents any lateral movement for the wheel/hub to meet and with the negative camber it doesn't seem it could be the most flush this way.
I ask because I notice slight vibration at highway speeds ever since I started messing with it and BMWs are sensitive as fvck. It could be that I didn't clean the hub/spacers too well but I thought I'd get this right first.
What's the right way to do it?
