This shot pretty well says it all ?. extremetech mipmaps on nv 6800 Bri
It?s easy to spot the Brilinear on the 6800. It?s amazing hardware sites are benchmarking the NV 6800 with this type of lowered IQ garbage. ATI's adative-Trlinear is much better.
From someone that has both a X800 and 6800 ?
Xbit? posted some black/white mipmaps -- where the ATI adaptive-Tri works -- on application-setting (full-Trilinear on X800) and compared it to the 6800. It?s easy to spot the NV Brilinear even on the 60.72 which are likely much better than the later drivers -- which likely have improved performance likely at the expense of filtering quality.
Take a look at the shots marked APP on the X800 like ?
X800 ANIS 4 APP, 30 d.
X800 ANIS 8 APP, 30 d.
X800 ANIS 16 APP, 30 d.
And you can see the mipmap transitions on the X800 are much better than the NV-Brilinear. The X800 Tri is very close to the Tri of the 9800 although it?s difficult to compare in some shots because the mipmaps are pushed back farther on the X800.
l
In this close-up of the floor at 4X magnification, we can see what the filtering looks like on the GeForce 6800 Ultra (with and without trilinear optimizations) and on the Radeon X800 XT. ............. ... ... ATI's texture filtering is noticeably better.
l? originally posted by Ante P
? I have both boards and personally I can spot the "brilinear" on nVidias boards while I can't on ATis. ?
