- Apr 12, 2001
- 4,508
- 0
- 76
Hi everyone. I've got a Promise FastTrak100 TX2 ide raid controller that I'd like to setup with it's own LED for seeing hard drive use. Just like what your case has for the mobo hdd use display. The Promise card has a 4-pin plug on it, but I'm not sure how it works, and the manual doesn't have any info.
Has anyone here attempted this and had any success? If nobody knows how, I'll just email their tech support and ask there.
Ideally I'd like to mod my case to another LED for the raid hdd activity.
pic for reference
EDIT: Here is the response from the Promise support rep:
EDIT June 9th, 2004
I wanted to modify this posting since there are a few people here who might like to hear that I successfully got the LEDs to work. The quote from the Promise rep isn't exactly correct. Here's how it works:
This is what the pins look like on the card:
|---- LED1 +
|---- LED1 -
|---- LED2 -
|---- LED2 +
Now, I'm not 100% sure yet which set of pins is for which controller. I do know that they are separate though. I set mine up with 2 LEDs, they both flash at the same time since I only have 1 RAID 0 array with my two 80gb drives. In the future though I could potentially have different arrays on each channel, in which case the LEDs would flash differently.
Anyway, the way I got the LEDs attached is the tricky part. I wanted the LEDs to be mounted in the front of my case directly below the power and default hd led. So that means I had to build a long wire assembly with a plug of some sort to connect to the card. I found that a standard floppy molex connector from a power supply fits almost perfectly! The pins are the same width apart, but the floppy molex connector I got from my junk power supply had a little notch on it. I used my dremel and a file to get rid of the notch and any excess plastic so it would fit better.
Next I used extra wire from the junk power supply and soldered the LEDs to the wire. I used the little metal pins from the floppy molex connector so my wires would stay in the molex connector properly. This was a little tricky, since solder, plus the thick wire didn't fit too well in the molex connector. I got it to go in though, and when I plugged it all together it worked perfect!! Now I just need to drill the holes in the front of my case and mount the LEDs!
pic for reference
Hi
Yes there is on the FT100 TX2 there should a connector label JP1
that is hard drive LED connector. The connector should listed 1 through
4. Here is how the pin layout goes pin 1 and 4 are for ground and pin 2
and 3 are for power. You can have you hard drive LED cable connected to
pin 3 and 4. Pin 3 and 4 will control both IDE channel on the card.
Thank you
Promise Technology Inc
1745 McCandless Drives
Milpitas CA, 95035
408-228-6400
EDIT June 9th, 2004
|---- LED1 +
|---- LED1 -
|---- LED2 -
|---- LED2 +
