He's talking unbolting, and no these screws are fine. I've done it many times and you need the right sized phillips head so you don't strip the screws, like you are doing.
like you are doing.
I had to use a pair of pliers to even turn the bolt to atleast get it off the cross-arm itself and I had a double cloth towel over the bolt so I wouldn't end up with marks like I did; that's how much pressure it took to get it out. I don't think a Phillips would of helped. What's wrong with it?
Wait, I don't think I explained where it was getting stuck. It's not the threads or the part where it screws in. It's the place where you drop the screw in the cross arm; the place where it's suppose to be smooth.
In the pic above, the cross arm is behind the foreground object, it was stuck in that piece.
Huh ? THere is no screw in middle of the cross bar.
This is the correct way to mount it:
And no, this can't be a common occurance because as you see, there are 10 things to tighten on a Megahalem. The 4 stands to the backplate. The 4 nuts to the stands. And the 2 spring loaded screws through the center piece into the parallel plates. These screws can be tightened with a Philips and unscrewed with a Philips, without any excessive force needed.
if you have some wd-40 or some bike lube or something like that, you can put some of that on the screws threads and it should go in easier. just a thought. i dont have a megahalem so i dont really get the mounting mechanism.
