Projector for small bedroom?
suklee
10
Random (GAS / Gear Acquisition Syndrome) question: is there some type of small-ish projector that I can set up in my bedroom and use the wall as a screen? My wall is off-white colour (hint of beige) and throw distance is ~ 6ft - 8ft.
mnewsham
14,539
428
For that long of throw distance pretty much any recent consumer projector should be fine.
If it were under 4 feet then you'd want to look at short throw projectors which can do 120" from 2-3 feet.
suklee
10
Cheers - I think the maximum image size would be equivalent to something like a 50" TV. The wall is pressed right up against the foot of my bed
