jaysodyssey
Ok if this is in the wrong forum then please move it to wherever,
My goal is to find some "used" or "refurbished" gear for a project under a shoestring budget, any help would be great
Purpose of gear: To conduct person to camera interviews, capture footage with external mic for background and B roll clips, action photography for sequencing, night photography of the stars, slow motion sequences, edited on the fly on location, produced and published on location, locations continuously changing
Equipment List
Shotgun Mic (For Foley Sound)
Choice 1
Rhode videoMic +deadcat Screen (This can be brand new for the price)
ALT
Opteka VM-8 Directional Mini-Shotgun (Way Cheaper)
Lighting
NEEWER® 160 LED CN-160 Dimmable Ultra High Power Panel Digital Camera / Camcorder Video Light,
Camera???? (All I know is it can be older but must record to other then DV tape, memory card preferrable, must be able to slow down the video, and must be able to do night longer shutters, it also must have an external audio plug as well as a hot shoe (hot or cold shoe is flexible as the items will not be powered by the shoe just held there) I would also prefer it not be a full DSLR, WEIGHT is a huge consideration for this project, I do not need multiple lens , The High end P&S Cameras will work for my use as long as the video is hd! I should also mention that this camera will be used for video AND photos, so while a good video camera does good video, it rarely does good video, so I know I am looking for something that shoots good photos with a video addon
External Light And Mic Mount
Vello CB-510 Dual Shoe Bracket with Silicon Rubber Grip
Interview Audio
Audio2000 WV6951M VHF Portable Wireless Microphone with Two Lavalier (Lapel) (Chosen because it can run on AA Batteries and has selectable frequencies)
Tripod (Lightweight Manfretto Carbon Fiber 70" Tripod) Already Purchased
Action Sequences
First choice - Foscam AC1080 Action Camera
ALT Gopro Hero (Despise them so most likely foscam)
Action Sequence Mounting
EEEKit 8-in-1 Accessories Kit for Gopro (has everything I would need in it, and the mounts all fit Foscam)
Editing Machine
HP Folio 13 Ultrabook 8GB Ram
Editing software (I have had trouble with this, I know I do not want anything elaborate like Premiere or Final Cut, Right now I am testing Muvee, and VIdeopad Pro) the primary key is going to be fast render times!
Storage & Backup
SD Cards for the cameras
Silicon Power 500GB Rugged Armor A30 Military Shockproof Standard 2.5-Inch USB 3.0 External Portable Hard Drive
Summary:
I am sure I left something Out, but As you can see I have mostly an idea, My biggest hangup is the camera, I had my eye on a Lumix FZ200 but someone sniped it from me, so I am open to suggestions. ON ALL Equipment I do not mind if it is scratch and dent since its going to take one helluva beating anyway, I got my laptop for 600 bucks off retail because it had a few scratches on the case and a small dent in the metal, big deal!
Equipment List
Choice 1
ALT
Lighting
Interview Audio
Action Sequences
Editing Machine
Storage & Backup
Summary:
