Project management and collaboration tools
think2
I'm a software developer. I'm trying to find out if anyone has experience of using a project management and collaboration tool for design and development. For example, quite a lot of my email discussions involve design and spec of the software. I'm thinking that it might be better if these discussions were held inside a collaboration tool. A project could have a task "write spec", then every time you need to create or modify something in the spec you create a sub-task and start a discussion about the issue. The sub-task doesn't get closed until the spec has been updated if necessary.
Does anyone do this already?
Which collaboration tool do you use?
e.g.
Asana
Redbooth
Wrike
Basecamp
ActiveCollab
Clarizen
Why are there so many of these tools?
How suitable are they for holding conversations/ discussions?
