Bateluer
Just got an email for Update #84, informing that Backer Beta is opening.
Apparently, there's no NDA either and they claim the Beta to be 'spoiler' free as nothing in it is related to the main story. You can check out the full post below.
https://www.kickstarter.com/projects/obsidian/project-eternity/posts
Beta Redemption Instructions
If you have purchased the Backer Beta or if it is included in your Kickstarter tier (all tiers of $110.00 or above) you can now head over to your Account Profile to redeem your Backer Beta Steam key.
On the account page, you will want to click the link on the left that reads "Products." This tab displays all of the products you have associated with your account that are now available. As we release additional rewards, they will appear here.
Click on the "Pillars of Eternity - Backer Beta" entry to expand the entry.
Press the "Generate" button.
You will be asked to confirm that you would like to generate a key for the Beta. If you wish to generate a key at that time, press the "Generate Key" button.
If you generate a key, you should see a banner at the top of the tab that confirms your success.
Expand the "Pillars of Eternity - Backer Beta" entry again and you should see your key with instructions in how to install it on Steam. Enjoy your first experience in the world of Eora!
