Project: Corsair Graphite 600T MbK
madebykier
36
www.madebykier.com
Bay res update !!!
Today I've received my BP reservoir. Nice and small
Removed the acryl window from the reservoir and marked the holes for the M4 bolds
Perfect fit ;)
Cut the lines out of the black film. Same shape as the internal from the res
madebykier
36
www.madebykier.com
Update!!!
This time I've did some modding for the midplate. bend two angels in a mesh panel.
For the side of the midplate I've sawn a piece of 5mm transparant acryl
And another piece 5mm blue acryl
madebykier
36
www.madebykier.com
Just two pics of the big big Asus
Back to the transaprant acryl, past black film on it
Cut out the outline
And past 3m Carbon on the smaller plate
And put the both together
Cut also the outline from the smaller blue acryl
Also sawn and bend a piece of aluminium for the side from the radiator
madebykier
36
www.madebykier.com
Update!!!
Today is a great day. Received a really important piece of this build
The Mnpctech 600T clear acryl panel. I always love a window in the sidepanels. So this is the ultimate one
The package from Mnpctech
All covered with paper adhesive backing
12mm thick acrylic
To prepare the panel you have to use the original panel latches, but first removed one side of the adhesive protection
So the original sidepanel/latch
There are 4 clips that you need to sqeeze
madebykier
36
www.madebykier.com
And there out
Now you take the acrylic sidepanel and put in the top of the latch first
Now push and sqeeze the clips in
Removed the protection from other side also and there you have it....... a great window for your Corsair Graphite 600T
The quality is really great and all edges are smooth and polished
madebykier
36
www.madebykier.com
I'm not gonna bother cleaning this mess up. STOP spamming or you'll be banned as such. We don't care about your sponsors. If they want advertizing space, they can buy it like everyone else.
AT MOd
Gillbot
madebykier
36
www.madebykier.com
A nice reservoir, the 525 Bay Res
Very sexy modkit for the D5/MCP655 pump
The D5/Mcp655 Modkit
And a new top for the D5, the Mod top V2 extreme
I also have a nice collection of fittings etc. All Carbon black style
Carbon Black 1/2" fitting
Carbon Black stop fitting
A Carbon Black Fill set + Mini dual extender
madebykier
36
www.madebykier.com
The Rotary 45-degree extender
And the Carbon Black rotery 90-degree Extender
And finally 2 x Five Rotary Snake-style dual adapter
It took a long time but was really worth the wait.
ViviTheMage
36,189
87
madgenius.com
awesome looking 600T! MNPCTech is great too....lucky for me they are local, so i've been able to meet up with the owner.
I was the first one he did the PROPER full acrylic side panel cut for :).
ViviTheMage
36,189
87
madgenius.com
Ahh lucky you, like to shake hands with Bill
think he's one of the best modders
Great rig you've got there my friend ;)
I did the exact opposite of you...a 600T build, with ZERO modifications/cuts, and water setup :).
My only advice for myself, and maybe you...get a mobo that is color matching, otherwise it looks off...ie red/black theme mobo, or blue/black..not random colors like the asrock.
OVerLoRDI
5,490
4
Wow I have to say this is a great looking machine. Maybe this coming summer I can get down to some real modding of my HAF 932
QueBert
22,546
832
that window's siiiiiiick, I don't have the skills or patience even to mod anything like you so PROPS for your work. But I think I could probably manage to swap out my side panel with that window. It's a bit pricey for me, but looks kiiiilllller.
