Programs for making a screensaver??
Kenazo
10,429
I want to make a custom screensaver for a business. They have a flash movie which was made for their business. Can I turn that into a screensaver? If not, can I make something like it as a screensaver? i.e. with moving text across images, various fades/dissolves/transparency between image and text. I need something more than just simple slide show.
kenazo
Kenazo
10,429
i did a fscking search on google and after it told me you were a fscking ass it gave me a bunch of fscking adds and misc. garbage none of which was a fscking opinion by a fscking educated person who has actually used a fscking program
rh71
52,844
1,049
I used to use FlashJester Creator.
Here's a few more I've never tried:
Flash2Screensaver
FlashForge
Using Flash to create a screensaver is the best method. We all know how flexible Flash is (especially with actionscripting) and everything else is left to your imagination. Flash is way underrated.
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
bahahahah :D
Kenazo
10,429
Thanks guys, that helps me out! rbloedow: do you know if that's ad supported? In the FlashJester faq they say one of their advantages is that they aren't ad supported like screenweaver....
rh71
52,844
1,049
I think you should just go with the simplest tool out there. That may be my 2nd listing... I've never tried it though.
Kenazo
10,429
right. I think FlashJester is pretty pricey for what I'll be needing to do. I don't need alot of options, it just needs to convert it to a file that will install and open on the pc with no other plugins etc.
