Programming a Operating System
SoundTheSurrender
3,126
Does anyone know where I can get a small operating system that I could compile and learn how it works?
I don't want to mess with something big.
I would be running it in a virtual machine setting.
Thanks
screw3d
6,906
This reminds me of an OS class I had to take in college. Nachos anyone?
/shivers
All I can say is good luck and have fun!
3NF
1,345
/shivers
That's what it reminded me off :) I still have the Java code from that class.
Nothinman
30,672
The problem is that any OS that's worth running will be big because of the drivers, the core itself it will be fairly small. From what I hear the NetBSD codebase is pretty easy to follow so that might be a good place to start.
Ken g6
Moderator
Dec 11, 1999
16,839
4,820
75
/shivers
/me pulls a book off a shelf: Operating Systems, A Modern Perspective, by Gary Nutt.
I know what you mean.
STS: What are you trying to get out of this? If you care about task scheduling, go with someone else's suggestion. If you just want to start with a small OS with a filesystem but without task scheduling, you might try FreeDOS.
engineereeyore
2,070
If you want to see how an OS works on a smaller level, you can look up OS's for embedded systems, such as MicroC/OS 2. These operating systems work on a much smaller level and I believe MicroC is only about 2,000-3,000 lines of code, but it handles the basics pretty well, such as process creation/allocation, scheduling, context switching, ISR, and shared memory.
Reel
4,484
Originally posted by: tfinch2
You can get an older Tanenbaum OS book with Minix for probably around $15-20 bucks.
I second that. Minix was created for that purpose but you might find something like one of the BSDs more motivating since it is a "real" OS.
mugs
48,920
46
Thirded Minix.
Thyme
2,330
You might want to look into TinyOS. It's a real OS that runs on nodes for some wireless sensor networks.
tfinch2
22,114
Originally posted by: mugs
Originally posted by: 3NF
unban ^[a-zA-Z0-9]+$
Nice :D
Appropriate for this forum :)
Sucks for those with spaces or special characters in their usernames :(
:thumbsup: tfinch2
I was waiting for the day for someone to point that out... :p
OP, you can also look into Pintos. Stanford (I think?) has all of the documentation and OS course assignments online.
