Program to monitor Northbridge and Southbridge temps.
JBS
52
I have a Gigabyte GA-MA78GM-S2H (rev 1.0) AM2+ motherboard, with a 780G northbridge and SB700 southbridge.
Is there a software program or utility that can monitor Northbridge and Southbridge temperatures on this motherboard? I currently have EasyTune5 Pro installed (Gigabyte program), however it only monitors CPU and system temps.
I also have Coretemp, Speedfan, Everest, and CPUID Hardware Monitor installed, but I'm not sure if any of the temp readings are for the northbridge and/or southbridge.
Sylvanas
3,752
If those apps do not pick up a NB/SB monitor then none will and the NB/SB does not have a temp sensor. I checked with my 790FX and there is no NB/SB monitor either. Not to worry, they are so cool it's a joke, at tops the NB tops out at 10w load and idles at 4w- hardly anything to be weary of.
