Processor temp sound normal?
worthless085
242
Im runing an A64 2800+ on a zalman 7000cu, my idle tem is 37C, and load is 47C... sound normal?
with case fans on its a little cooler
worthless085
242
those temps were reported by Speedfan
but when i look in my bios my idle is only 22C..... my current room temp is 18 (65) i like it cold :)
which temp is most accurate?
BW86
13,114
30
The speedfan is more accurate. You dont have a 22C idle on air :D Those temps are fine btw.
Idleuser
882
yep speefan are more accurate, when most people say i'm getting 33c on idle and 39 on load running insane speeds they're going by some program like corecenter which isn't accurate. I have H20 with 1.7v and I find it hard that a good air solution can top it.
