Dell™ Inspiron™ XPS Gen 2
Intel pentium M 760 (core speed 2ghz, 533mhz fsb) socket 479
this lap top: http://www.pcmag.com/article2/0,2817,1769520,00.asp
Update:
not CPU
not AC adapter
not Bios
solution thanks to Hacp RMclock (software overclock)
I have this Lap Top that appears to be stuck at 800mhz both Linux Mint 10 and Windows 7.
CPU-Z correctly identifies the CPU as Pentium M 760 but the the core speed is stuck at 800mhz (Bus 133mxz multiplier x6)
Speed step is enabled in the bios (if disabled it will default to lowest speed 800mhz)
Also once in a while even before reaching the boot loader the CPU fan will spin at its max and when it does this the CPU boots at 200mhz (Bus 36mhz multiplier x6). Things are crawling but it appears to work. Reboot will usually bring it back to 800mhz.
Running Prime 95 or stressing the lap top (watching HD movie) will not bring the CPU to 2ghz (speed step is supposed to do this)
Bios correctly identifies the CPU as:
Pentium M
Current clock speed = 2.00ghz after about 30secs in the bios it goes down to 800mhz
Minimum Clock speed = 800mhz
Maximum Clock Speed = 2.00ghz
Things that I have done:
I have updated the bios to the latest version A05
I reseated the CPU and placed new thermal paste
I am now at a crossroad since I don't know if its motherboard problem or a CPU problem.
Before I buy a used CPU, I just wanted to get someones opinion. If its a mother board problem then I wont bother getting a another cpu.
It appears to be speed step problem but unfortunately disabling it in the bios defaults to 800mhz.
I am hoping this has also happened to someone and learn from their experience.
Question:
Mother board or CPU problem
P.S. dissembling the laptop was not that hard (had the service manual) it wasn't really that complicated.
Update:
not CPU
not AC adapter
not Bios
Pentium M
Question:
