Problems..
bulbasuar
56
<<My original post from the Ultra Products forum>>
Hi, i have a issue and im not sure whatr part it is, so i figure ill throw up some posts and get advice on each piece of hardware in my machine.
AMD64 3200
MSI K8T-NEO
1gb Corsair Value
2x 160gb Western Digital
BFG 6800GT OC 256mb AGP
X-Connect 550watt
Lite-On DVDrw
Ok, so, I've had this issue on and off for a while dating as far back as march of last year. However till now it was always on a small scale and only happened once in a while and stop doing very quickly that normally id just think it was a hiccup.
Basiclly what happens is, my computer freeze's, alot, games are distorted, artifacting all over. It's not only in games it just generally freeze's, normally playing a earpiercing high pitched sound thru my speakers.
At first i thought it was a video card issue, i updated drivers, rolled back drivers, disabled my video card, uninstall/remove/install, rinse repeat. i even called BFG and had it replaced.
The brand new card i received in the mail today from BFG, i plugged it in expected some better proformance, and it was the exact same. so i updated the drivers only to find that with updated drivers i couldent even the logon screen. also, sometimes on a hard restart my bios wont even pop up, just black monitor then my monitor tells me that a cable may unplugged.
But, in safe mode, like im using right now, everything runs as it should no problems whatsoever. i can run for days with no issues at all. but as i soon as i run out of safemode its like the instant death of stability.
so, to sum it up.
Crash's, alot
Artifacting in games
really really slow proformance
black screen on restart sometimes
Also, my Ultra X-Connect emits a screeching sound, that is really really noticable, sometimes in drowns the rest of sounds in my house. I know its the X-Connect becuase i tested out various parts to hear for sounds and it was the PSU.
Any help at all would be awesome, TY.
EDIT: i can run just fine (just like in safe mode) with my videocard disabled, maybe the bad sound emiting for my PSU means that its having a hardtime powering my GPU to its full abilities?
bulbasuar
56
Originally posted by: jackschmittusa
Sounds like a cpu thermal issue. The whine from the speakers may be the warning for a hot cpu.
CPU runs at 38-47c. max load around 55c.
VanTheMan
1,060
I vote new PSU from Enermax, Seasonic, or Fortron/FSP. I have an Enermax EG425P-VE that produces rock solid voltages. I've had no problems with it thus far.
ForumMaster
7,792
have you tried reinstalling windows? since you say that you don't have this problem when in safe mode. try using msconfig to disable everything you can and enable them one by one to try and see what the culprit is. you could also try to mess with teh services, but i warn you: becareful. you may end up disabling windows and having to reinstall. look with google for a list of required services and disable everything you don't need.
