Problems with video on Gigabyte DS3
Eddie33081
227
Hello everyone.
Heres what happened:
I was playing Company of heroes on my x1900xt (not overclocked) when I receive a message from my ati drivers that my card was overheating and that it was going to be underclocked. I kept playing as I was in a match at the time. It repeated this message 3 more times. Right when I was quitting the match my computer froze. I hard rebooted and I received a message in red on top of the screen (before anything else posted) that my video cards fan may be broken, etc.
I again rebooted and it started into windows. About 20 seconds later on my desktop the computer froze again. I had to turn off the PSU just to restart. I went to my bios and was checking for settings that I could change and it froze again in the bios.
The video card showed 74C while playing the game. The fan was spinning when I checked the video card. The last time I tried to reboot and got it to stay up for longer then 30 seconds I checked the temps again and it said 49C. I did not smell anything funny coming from my computer but it seems my video card could be burnt.
I have replaced the video card thinking it was burnt with a working card and the exact same thing happens. So should I suspect the motherboard is done?
So heres my questions!
1. Is my motherboard burnt? Is there any way to salvage/test to make sure its the motherboard?
2. I purchased this about 6 months ago from newegg. Can this be warrantied if it is burnt, I cant seem to find it on gigabytes site. I know newegg only has a 30 day policy?
Thanks!
cprince
963
Do you have adequate case cooling? Also, the DS3 has a problem with northbridge overheating. You might want to stick a small fan on top of the northbridge heatsink.
Rage3kMoiz
72
Why not try to contact Newegg and ask them instead? It's certainly not your fault. You didn't get any messages telling you to turn your PC off or anything right? But as stated above, if you do get a replacement, make sure you have adequate cooling for the northbridge and proper case airflow.
