Just bought Auzentech Corona case from newegg, but ran into a problem: When I mount a DVD-drive vertically (not on the side, but vertically hanging down) it won't open. As soon as I slightly incline the case back it opens without problem. I tried Lite-on and Sony DVD-burners (ones I had in posession) and both behave exactly the same. Both jam and won't open when hanged vertically down.
Anyone had similar experience with vertical mounting? Do you know any other drives which mount vertically (not on the side) and don't jam? Manufacturer approval (vertical mounting) normally means they can be mounted on their side, which is completely different and doesn't help in this case.
Thanks.
Bidzina
Thanks.
Bidzina
