I bought a Bytecc ME-320 USB 2.0 Enclosure. Installed the thing on my computer, windows xp detects it, works perfectly.
I use the "safely remove device" and then disconnect the usb cable. I reconnect the USB cable, windows detect it and it is still working fine. However, if I disconnect the usb cable, turn off the enclosure with the switch and then reconnect the usb cable and turn the switch back on, it is detected but I get an exclamation mark in device manager and it does not work. The only way to make it works again is to reboot the computer which is not exactly "hot swap".
I tried on 3 computers, two of them running windows xp and the other one windows 2000. I get the same problem on them.
Any ideas? (I will contact bytecc about that but anyway)
