darkeneddays
Just got a cheapo Ati Radeon VE to use for TV-Out.Had a spare PC so it is going to be used solely for playing DVDs/Divx movies.The problem is that the lowest resolution I can go is 800x600 on XP which creates a black border on the bottom of the TV.When I used a Nvidia TV-Out before on the same TV,I used TV-Tool with 640x480 resolution and "fit to desktop" option enabled.The TV-out fit fine then.Is there anyway to get the same results on this card?
TIA🙂
TIA🙂
