Problems with the Nvidia Geforce 256
Sep 7, 2000
149
I have the following PC configuraion:
AMD Thunderbird 900MHz
Asus K7M
Asus 6800V GeForce 256 DDR 32MG
128MB PC100 RAM
Maxtor DiamondMax+ 40
Soundblaster 128 PCI
Sylvania F72 17" Monitor
Conexant 56K modem
Win 98 SE
No additional Hardware
My Graphic Card seems to be having some (a lot)compatibilty problems, every game i play has some bug in it like in Unreal Turnament all the shadows and water are displayed wrong and even though i have the newest update for it and the Detanator 3 (which by the way didn't increase my performance even 1 frame). I run Unreal Turnament at 1024x768x32 at about 60 fps in D3D but as I said with errors. When I run the game in the Open GL mode it fixes the shadow problem but the game is increadibly slow 32 fps. The computer is new and i have not installed any damaging software or anything everything should work fine but it doesn't. Can anybody help??? Or is somebody having the same problem?? By the way a list of games with errors UT, NFS4, Homeworld.
Darksamie
220
I have the same card, but a different PC config (obvoiusly). What you should try is to uninstall the detonator drivers and set it to Standard VGA. Then re-install DirectX 7.0A and then install the detonator drivers. See how that goes....
