- Oct 10, 1999
- 7,560
- 0
- 0
Has anyone else been experiencing problems with the WGT624 model specifically? I have had two of them so far and have had about the same trouble out of them. The first one I had put all of the settings in for the wireless to have encryption and MAC address filtering and locked it down to a certain speed and afterwards tried to install the firmware upgrade to 1.1.1 and it basically made the router useless. I could no longer even ping the router and the power light flashed green from then on instead of staying solid.
The second router I have right now I have of course NOT installed the 1.1.1 firmware upgrade but I did apply the settings to the router for its wireless connection and noticed that I will loose connection to the router even when my PC is hard wired into it. It will ping the 192.168.0.1 part of the time and just loose connection all of the sudden for no reason. I have since reset the router and just allowed it to have everything as default on the wireless part of it and it has been fine now. ....If I put the wireless settings in there again it starts having its little problems again.
Soo....I think there is a problem with the versions that are coming out at the moment with wireless settings being setup like I had mine possibly.
