Problems with TDK 40X Burner and Nero
Achtung
656
Seems like half the time when I try to copy a CD in Nero, I get an error message stating "Focus or tracking error" and the write fails, leaving me with a coaster. Here's some of what is in the log file:
11:32:44 PM #23 SCSI -1039 File Cdrdrv.cpp, Line 1413
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x029D0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0x00 0x01 0xF1 0x93 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x09 0x01
11:32:44 PM #24 MMC -1039 File Writer.cpp, Line 330
11:32:44 PM #25 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
11:32:44 PM #26 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
11:32:44 PM #27 Phase 38 File dlgbrnst.cpp, Line 1449
Burn process failed at 24x (3,600 KB/s)
As I said, its a 40X TDK VeloCD drive and I'm using the version of Nero that came with the drive, and I have also tried downloading the update to Nero, which didn't help much. If anyone has any idea what this problem is related to (CD drive, driver, Nero) I would really appreciate the help. Thanks!
Codewiz
5,758
I would try a different burning program. If it works in another program then Nero is probably messed up.
Also most likely you could update the firmware to a Liteon firmware and burn the speed up to 48X write.
Check out cdfreaks.com if you want to update to a liteon firmware.
If it doesn't work in another burning program then the drive sounds defective.
apoppin
34,890
alienbabeltech.com
Try a complete uninstall and reinstall of Nero and definitely use the latest version of Nero.
EDIT: Focus and Tracking points to hardware. Might not be a bad idea to 1) try a slow burn speed and 2) try a different burning program before reinstalling.
