Problems with starting my car... Help please!
weirdichi
4,711
Ok, not so much mechanical problems, but everytime I get in the car, I have to spend at least 15-30 mins just trying to get the key to turn in the ignition. I step on the clutch, put it in neutral, first gear, e-brake off, and nothing seems to work. The key may be a little worn down, so I'm thinking that may be the problem. Any other pointers?
HappyPuppy
16,997
Keys are relatively cheap, depending on the car. Go to a locksmith or a dealer and have them make you one.
ohtwell
14,516
9
Definitely go to a dealer and have them give you a new key. More than likely yours is worn down and the ignition doesn't recognize it's there.
: ) Amanda
CraigRT
31,440
if your car is older and does not have a computer key, most definitely invest in a new key to try out first.
Quixfire
6,892
It maybe the key, but on a few Fords and some imports I seen the lock cylinder wear out and cause this kind of concern. If a new key doesn't fix the problem, I would start locking there. BTW, what kind of car is it?
weirdichi
4,711
Hmm.. the key is kinda worn down, and I made a new copy, but the new copy doesn't really work either. The keys work on the door, but not on the ignition hole.
ohtwell
14,516
9
Did you get a new key from the dealership or a copy of the key you have? Copying a key that is worn down is pointless. :)
: ) Amanda
weirdichi
4,711
My car is an older Integra. Do I just go to any Acura dealer and have them look at it or would I have to go to the original dealer?
Quixfire
6,892
Any Acura dealer should be able to service your vehicle, unlike American car companies, they use your VIN number to look up key codes and other restrictive parts. But sounds like your lock cylinder is worn, which may set you back a couple hundred dollars to replace.
